Grabinov911
- 10:31 PM
- Jan 27, 2012
- Southern California
Guys I put more details in my "80 Grit" thread, but when installing a new Gear Vendor tailshaft housing this weekend it became clear that the housing was not centered in the driveshaft tunnel.
This photo shows the factory tailshaft housing, but unfortunately it's not a very good angle to see if the housing is centered.
This is the new housing, from the correct angle. The lighting could be better but you can see (poorly) that the housing is to the right (of the tunnel / car) by about 3/4" from center.
I'm really confused. How can this be? The only mounts still in place (since the trans mount and crossmember are removed) are the engine mounts, and they only go on one way. How can the whole system be turned to leave the tailshaft housing off center? It's as if the whole engine is turned left (moving the tail right).
Are the engine and transmission off-center from the factory? Doesn't the driveshaft go down the exact middle of the car?
