- 3:23 PM
- Oct 16, 2014
- Salisbury, Vermont
The parts are a 1/4" breaker bar handle, a chrome spacer with one side ground flat, a washer held on by a wire through the pin so the spring is loaded. spring I found in my tool box, a SS cable with plastic sheath that I modified and the ring is off a dog tie down thing that you twist down into the ground... lol. The cable slide is a piece of a air tool tube in aluminum.
