Moparjack 489
A rotor unbalance could do it...
yes , maybe , but can I check a rotor is unbalanced on the car Installed, and how ? Or must remove the rotor of course ..?
Driveshaft balance.
Also, if automatic transmission, check the flexplate to ensure it's true/flat. I went through the same issues with my Super Bee although the entire car shook.
driveshaft I don’t think so , because first I not have vibration in the driver seat or in the whole car , like I know this problems from my station wagon with unbalanced drive shafts ..
in the Charger are also a nice , short Aluminium drive shaft from Danny’s drive line .
How about the flex. plate ? How I can check is it flat and straight without remove it? Just remove dust cover plate turn engine by hand and visual check ?
I think you need to find a shop that can perform a 4-wheel balance. Not many shop understand old Mopars like the ones we have.car stand from about 2009 to 2016 on the suspension and tires without any movement , first real drive with running engine was 2016.
and since the first test drive up to now the Charger have bad vibrations start about 60to 70 Miles up to 85-90 miles , after 90 miles I not can feel it really , only very very small vibration like a dildo Maschine from a woman.
Haha, yes maybe the Hemi the vibration ProblemI think there’s an issue with the engine. Better pull it and send it to me. I’ll replace it with a built 318. That should take care of the vibration.![]()
Thanks, but I think my problem is in the suspension .I had a Challenger once that had a vibe to the steering wheel , it was a bad out of balance torque converter.Steering wheel would osculate at a certain speed real bad . Converter had a dent in it .
That’s the lower steering column bearing. Wouldn’t cause a vibration in my opinion. Just holds the steering shaft centered in the column.View attachment 944570 Anyone knows about this screw ? Is one like on 12 and one on 6 a clock , it for holds the white insert inside?
I ask , because I found these 2 screws are little „ lose „
Yes car drive also nice and straight , It seems for me the inner nylon inserts in the rack it self wear out and give that little play in the steel rod . Have to buy a new rack I think .Have you ruled out driveline angles? Steering wheel doesn't sound like that, but vibrations can sometimes be difficult to source.
