RM23M9A
My A12 started to run like crap right after a few short high RPM drag racing bursts on a local street Monday. 7/13/2020, Falls on its face upon acceleration, I get an Umpf, then NO throttle at all, until it seems to jump to a spot where it wants to run faster, pedal moves freely, smooth acceleration "Revs" smoothly in NEUTRAL or PARK, but it has a choppy, lopy idle camshaft. (My Fathers not here any longer to know exactly what cam etc he put in it.) then it Jumps into a high RPM... I think its electrical, my coil is old, ECU, voltage reg, Ballast resistor, are all old. I have new DASH, and ENGINE wiring harnesses from Year One. COIL, Volt Reg, Dist Cap, Ballast Resistor on the way,)
I used to know these things well with any 4 bbl car. Suddenly? Not so much.There's no "Cruising Throttle".
Look at THIS MESS!
I dont know what this black "Goo" running down the firewall is? From Voltage Regulator area?
I mean, actual sticky caked, "Goo"! LoL
Here is what I DO know-
(Block IS stamped with an "A" assuming .020 Overbore, Casting 2-17-1969, car has 727 Automatic, VERY stout transmission, about a .280/.292 cam, 4:10 rear-gears,carb gaskets are on the way, Hooker Super Comp headers, ECU and Voltage regulator are old, car was my fathers. Ran like a top for the first month I drove it. But after "Running the piss out of it for 1 night, now I have this issue, Carbs seem to be getting enough fuel, timing light tells me it's set at 17° BTDC. Ran fine like said for a month, gets about 8 mpg. Seems my little Drag Race night found a weak spot.
attachFull976224
I Know this has been asked a million +1 times, but be nice to find someone my age or older (51) that has had THIS Problem...
Look at THIS MESS!
attachFull976224
