khryslerkid
- 11:32 AM
- Mar 10, 2010
- Hanover, Pennslyvania
As a matter of fact I do....Timken, stock ticker symbol TKR, has been in business for 120 years, pays a decent dividend and is selling for $ 76.00/share and paying 2% quarterly. Timken also produces specialized steels for other applications other than bearing production. Their product is superior to the Green style bearing, presently made by Bearing Technologies and marketed by several suppliers, including Mosur Engineering. I've asked several times as to the numbers on the Green bearing sassembly (not the MO400 number) to be able to check the bearings published design criteria capabilities....I guess I'll have to break down and buy one to see.
Its fun to poke the hornets nest occasionly, to see the proponents acclaim/proclaim the bearing's benefits. And I'll keep providing a rebuttal as to why I won't use them on my car, maybe as vehemently as those that do....
But...it all comes down to the car's owner....to each his own....
BOB RENTON
You need to write to all of the auto manufacturers of the last 20 plus years and tell them your grievances. They've been using sealed roller and ball bearings in all of their makes and models. Even front wheel drive vehicles with all of that side load when going into turns. Guess what a 2500 Dodge truck with a Dana rear uses...roller bearings. Imagine that!
I'm not saying there's anything wrong with the original taypered on these vehicles. It's what Ma designed for and it works great. If I owned another Mopar that all was original, it's what I would use to replace a bad bearing.
What I'm trying to get across to you and anyone else that disagrees with using Green bearings is that they do have their place in the automotive world and there isn't a damn thing wrong with using them. Green Bearing had a bad batch years ago and it was immediately corrected. That's what so many have heard about Green bearings and they won't let go of it. If you're getting into the scientific tech about them, there's not enough data under their current use to be saying that they're no good.
You said it "To each his own" (See you next time someone mentions Green Bearing)
