- 12:01 AM
- Jan 16, 2011
- NorCal Sierras
RideTech rear suspension w/coil-over
or Air - Shockwave (airbag over-shock)
is the choice for a bunch of Pro-Touring or even resto-mod guys
many swear by them, good ride & exceptional handling
mostly bolt-in kits
there's welding the upper bars tabs to the top of the housing
these are like $1300-$1400, without the Shocks
shockwave kit, with the Shockwave airbag shocks
here's their coil-overs, can be used instead
A real parallel 4 link
really has the most adjustments (real fast racecars use them too)
for the street a softer end links/heims with poly or rubber bushings
(bushings vs spherical Heim joints) will not be so ridged
need a Panhard, watts-linkage or a diagonal bar between the bottom bars
to keep the rear centered
can use several styles of shocks, most common is coil-over or a Shockwave
you can get spring rates in so many different combos,
to fit your driving style or needs
most are a shorter travel suspension than a Leafspring style shock
but unless you are 4-wheeling, it can be made to work well on the street
depending on ride height & your driving style
this is an Art Morrison (Probably Camaro/Nova just for reference)
another generic 4 link for reference I think it's a Competition Engineering
partially why the 4 link or triangulated 4 Bar
handles so much better
control rise height much easier, almost infinite adjustments
some think the ride is too harsh, or too hard to dial in
BUT in reality, you can change spring rates easily
you can even get progressive (coil) spring rates too,
shocks are a huge deal in the combo
this is a generic short/long bar 4 link
Chris Alston (probably for a Camaro/Nova for referense)
Also uneven triangulated shorty 4 link, but some really like it
ladder bar & a coil-over can work on the street
like the Street Lynx or
the short top & long bottom bars, 4 link
like the MagnumForce style 4-link/Pro-Link
or like the triangulated short/long bars
Gerst 4 link below, some people love them, even some racers
then there's a Torque Arm style
really I've only seen them made for GM stuff, it works really well
could adapt it to a MoPar pretty easily if you have fab skills
can use a measuring tape & a plumb-bob &/or a building square etc.
This is Another Chris Alstopon Offering (probably GM just for reference)
double adjustable Ladders can work too, extremely adjustable
(for those worried about a 4-link being too complicated, it's not really)
need coil-over or Shockwave style shocks,
or coil springs & reg. shocks
this below is another Chris Alston example,
clear most floors with not much cutting
or losing the back seat
I sugest you read the Chris Alston Chassis Works reference below
http://www.cachassisworks.com/stories/techcac-303_web.pdf
https://chassisengineering.com
there's the leaf spring stuff too
Calvert CalTrac is one of the most popular
you can use the mono-leaf with or without rollers on the rear
preload & beefing up the spring perches is mandatory,
if you make any real power
you can use a stock leaf too, really depends on the car
you still need to fiddle around with them too
the front end separation/lift (they like 5", my old RR worked best with 3.5" lift)
not everything can be done by phone, or your checkbook
you actually have to experiment
but getting that worked out is really critical (It ain't just a bolt-on & go deal)
so is the shocks travel, rebound & compression is also
shocks/adjustments, locations are really critical on any of them
you could do a NASCAR style trailing Arm too
sort of like the old Ford Trucks had,
needs a track or Panhard bar for locating/centering rear axle
replace the leaf with it & use coil-over
or a Shockwave style air/over shock
mostly bolt-in kits
