65_Satellite
At a loss and don’t know where to go from here…. A lot of you were following my 4spd swap. 65 Satellite 4spd swap
Still chasing a vibration. I notice it from 25-65mph. Vibrates when I’m cruising and I push the clutch in and hold the clutch in or if I pull it into neutral while cruising and coast. Goes away when you put back in gear and let clutch out. Vibration is there whether car is running or not. I’ve tried it by shutting engine off while coasting and vibration is the same.
In addition to all the new trans and rear end parts I’ve replaced I’ve balanced driveshaft, new u-joints, balanced wheels, brand new axles, new axle bearings, swapped 3.55’s for 4.10’s (totally different pig), tried a different set of wheels. Based on angles and the TREMEC website I Tried a 2 degree shim, 4 degree shim and no shims and vibration is still there.
Im assuming I can eliminate the flywheel, pilot bearing, clutch and input shaft if the vibration is still there with the trans in neutral and engine off coasting down the road.
Here’s the slip yolk at ride height. I don’t believe it’s too far in or too far out.
I did notice I have a chunk missing in one of my rear drums but I’d assume that if this was the case it would vibrate constantly and not just when in neutral coasting
New axles and different pig so I should be able to eliminate possible axle, bearing or rear gears causing vibration
These are the current shims. 4 degrees total
Current setup
Pinion angle as it appears
These were the angle measurements
Current setup
