65_Satellite
its the same driveshaft and u joint that I had when I had the automatic in the car. it didn't vibrate with the autoThat might be your problem.
I went and read your photo garage of the tranny swap and see you modified the auto cross member to fit the 4 speed. Looks like you did a good job but you might want to find a correct 4 speed cross member for your car and compare to your modified one. You might have the mount offset to one side a little bit. Just guessing at this point.its the same driveshaft and u joint that I had when I had the automatic in the car. it didn't vibrate with the auto
I just had a conversation about conversion joints with a guy who raced Mopars for years. He said they never could get the vibration out when using conversion joints.That might be your problem.
That’s how it sits in the driveshaft. The c clips are on the inside. The u-joint that I took out was the same way except it was small joint to small yolk. When I got the different rear I needed the conversion joint which was small joint to big yolk.That might be your problem.
That could be a good pointI went and read your photo garage of the tranny swap and see you modified the auto cross member to fit the 4 speed. Looks like you did a good job but you might want to find a correct 4 speed cross member for your car and compare to your modified one. You might have the mount offset to one side a little bit. Just guessing at this point.
The easiest thing to do is rotate the driveshaft 180 degrees just to see if this fixes the vibration.That’s how it sits in the sees driveshaft. The c clips are on the inside. The u-joint that I took out was the same way except it was small joint to small yolk. When I got the different rear I needed the conversion joint which was small joint to big yolk.
I have a '59 Cadillac with a 2 piece drive shaft. It is a real PITA to get the center carrier aligned with the transmission AND the differential. I have engine / transmission swapped many A & B bodies over the last 50 years and have never experienced the kind of issue you are facing. A few times I have had to loosen everything (engine, transmission mounts and crossmember) taken the weight off of the drive train with a hoist and just kinda wiggled it all around to get a better alignment. Trunnion's on drive shafts wasn't Mopars greatest invention.The 62-65 B bodies often or always had the engine mounted with the trans off center.
The trunion universal is a constant velocity joint and compensates for this. When you convert it to a slip joint
you will get a driveshaft vibration you will not be able to find. I got this from Herb McCandless himself.
I can see it on my '64 Polara. I thought it had been hit sometime until I talked with Herb. I know this is
an unpleasant truth because the tranny has to be changed. I know 2 people who never got to the bottom
of this, and sold their cars. I remember some older Cadillacs having a double uv joint that they called a cv joint.
I wonder if one of those could be put on the tranny end of your driveshaft. I also tried to move the tranny over to the center, but the front mounts
wouldn't let it. You could probable verify this with McCandless Performance
Exactly what I was thinking.I don't know if it is this because my vibration was at 65 mph and up. Tailshaft yoke bushing, there should be no up and down movement. Mine was .013 clearance I measured after I pulled it. Edit There should little to no movement.View attachment 1340078
Being that the 65 cars were built with a slip yoke from the factory. Also the engine location is the same up to 1970. What leads you to believe this? I've chased a 4 speed vibration as well. Down to the last two items. A; the output shaft of the trans is slightly bent from a previous failure. B; The driveshaft is out of phase. Been thru pinion angle, U joints, yoke, driveshaft runout, driveshaft balancing, different center section, axle shafts, trans mount, extension housing, extension housing bushing. For sure it's driveshaft speed. Clutch disengaged, or in neutral still vibrates. I'm going to borrow a driveshaft from a friends car and see what happens.The 62-65 B bodies often or always had the engine mounted with the trans off center.
