- 8:17 PM
- Dec 31, 2020
- Ontario, Canada
My '67 R/T has the metal shields, but it was a Dec. '66 build.
US Tool sells them, or at least a rendition. '66 only has the rears and the plate up on the rear spring hanger channel. Newer cars also had them on the front rails... Torque Box Setshould probably be putting some of those torque boxes in Bella! is that something available after market that are well made? my sons a pretty good fabricator could likely make some up easier with measurements! he made the bellhousing from scratch mating the rb to a ZF so a torque box would be a breeze!
Our Oct 66 built 67 Charger has plastic shields.My '67 R/T has the metal shields, but it was a Dec. '66 build.
Maybe you would like to get our 67 L code Charger and then put your shields on it???? Then you wouldn’t have go through the hassle of advertising yours. Just trying to be helpful.Well now you tell me! I guess National Moparts is the only one that lists correctly as 67 up... as everyone else lists 66 up and I figured NM was wrong. Now is that $105 wasted or do I need to find another car in need.....
Basically what I did and it worked. I put it back on today, adjusted it with a view down the stainless trim and slammed the door 5 times and it didn't move. If it does I'll add some glue to the outside of the ball and roll it around, then into position and let it set.There was a mirror hack from Rick Ehrenberg in Mopar Action several years back that involves super glue on the ball. I’ll look for it when I’m home tomorrow night. I posted it once before.
