dual master cylinder conversion kit?
Terry Kitzman
2:41 AM
S.E. Iowa
Hi, I am thinking of converting my single master cylinder to a double master. on my 66 charger I would like some comments on which kit to buy. Thank you.
Get a 67 and up master cylinder.
Then get lines and prop valve for the same 1967 to 1970 B body
Easy peasy conversion.
My 66 is done doing exactly that.
Get a dual reservoir master cylinder and hardware from Dr. Diff.
Working on doing the same on my '65 Satellite. Unfortunately Dr. Diff is out of stock.
Wouldn't have another source?
Thanks!
Call fine lines or right stuff
Any of the brake line manufacturers can set you up with most of needed parts.
Get a new master on ebay for the 67 and up.
Pirate jack is another source for the master cyl
It's an easy upgrade
Just to Clarify for those that have done the conversion. I picked up Inline Tube conversion bloke and '67 duel master. After I bench bleed the master and install it, The rear outlet port on the master gets connected to the front port on the distribution valve, while the front master outlet port gets connected to the rear port.
CORRECT ?
