Compressor sale
GTXDAN
12:08 AM
Georgia
Tractor Supply has a 60 gal, 5 hp, vertical tank Dewalt compressor on sale right now for $899.
Here's the specs:
  • High Air Flow, Single Stage with 14.6 SCFM @ 90 PSI
  • 175 PSI Max Pressure typically found in two stage compressors, for optimum tool performance - 175 PSI combined with a 60 gallon tank provides more stored energy which allows for longer air tool run times
  • Heavy duty, 208-230 spread volt induction motor designed to operate at both 208 and 230 volt applications
  • Large capacity, 60 gal. ASME air receiver provides more air for longer run times on air tools such as ratchets, impacts, spray guns, hammers, etc.
  • Equipped with pressure gauge and on/off switch
  • Large air outlet port
  • Tie down holes on platform sides to secure unit when transporting
Limited Warranty - 2 Year Pump, 1 Year All Other Parts
That’s pretty good. Newer technology gives you the pressure and volume of a two stage from a single stage compressor
One good thing I liked was it is not an oilless compressor.
Don't know about that.....really don't but mine is a 2 stage and it'll run hot when I run it a lot. Can only imagine the heat a single stage will generate when running a lot. Mine is getting old and bought it used and it was in like new condition and in an 'easy' environment. So far after 20 years it's still kicking pretty good. Only thing lacking is my piping system is older and leaks down pretty fast now but it's on par with my own system lol
