HAHNAGON
- 12:19 AM
- Jun 26, 2023
- MOUNT VERNON, IN 47620
I am seeing fuel fuel sitting on the top of my rear secondary boosters area. Is this normal at any times for any reason or sign of issue? Not having any issues under acceleration except i feel like it shpuld be a bit quicker. Maybe a bit too long of a cold start and a high idle if I put any pressure on idle screw. I have rebuilt this 1406 electric choke carb twice and has it apart a few more times before that. Once with an aftermarket kit and second with an edelbrock kit. First issue was a bad float and not the kits fault. Don't see any vacuum leaks and triple checked timing. Fuel pressure at 6-6.5 psi. Any advice or plan of attack is welcome.
