Mix and Match Bell Housings
71Charger
6:29 AM
Northern Cal
Guys,
I've found a fairly inexpensive 18 spline 4spd that came out of a 68 Charger, I know it will need to be rebuilt, but can I run a 10.5 inch bell housing from a 70 and later with this?
I see that the bearing retainer for 67-69 bell housings are 4.805 inches diameter and the 70-74 retainers are 4.807. I'd like to retain the stock appearance and the weight savings of the 10.5 inch aluminum bell housing.
Thanks in advance.
Yes, an original 1968 A-833 18 spline will bolt up to a 1970 and later big block bellhousing.
You did not mention what car you are using it on?
Yes, an original A-833 18 spline will bolt up to a 1970 and later bellhousing.
That’s not completely true. The ‘66 and ‘67 18 spline transmissions used the smaller (4.354”) bearing retainer and will not work with a ‘68 and up big block bell housing unless the front bearing retainer is changed to a custom one that Brewer’s offers.
You will need a 4 speed transmission cross member from a 1968-69 b-body for it to work, if the 1970 car is a early production.
During the middle of the 1970 production year the size of the crossmember bolts were changed to a smaller size.
Guys,
Thanks in advance.
You know you need to do this if bellhousiing didn'4 come with the engine your using'
