512 Stroker Oil Pan Removal in 69 Dodge Charger
69Chrgr
6:38 AM
Midlothian,
Hey Guys
I've removed the oil pan on stock 440's on B bodies plenty of times, however I don't think I have done it on a stroker. My engine is a 440/512 with a 4.25 stroke crank. Can my oil pan still clear the crank and be removed while in my 69 Charger? Yes I know to remove the center link. Just wondering if it will clear the crank. Oil pan is a Milodon 6 quart center sump. Thanks!
May need to loosen a motor mount and lift engine slightly to clear the front bolts
The motor mounts can stay attached.
I've knocked the center link down to gain access. The nuts for the idler and Pitman arms are removed and the center link is lowered a bit. Being a "stroker" didn't change the procedure.
That’s what I needed to know that it would clear the crank. Thanks!!!!
