Drum Brake Wheel Cylinders 2881613 casting vs 2881612?
robl72
2:19 AM
RI
Looking to understand what the difference in casting numbers was for rear drum brake wheels cylinders 2881613 vs 2881612. I have a 69 Charger R/T, Nov 68 build.
Any idea which number is more correct for my application or are they both?
Thank you!
size of the bore?
Size of the bolts holding it in place ?
size of the bore?
Thanks for the response. Bolts are the larger 7/16 -20. Not sure on the bore size but a standard replacement is listed as .9375 ". Do you know which one is correct for my 11" HD Drums. I have a manual brake 11", four drum system on my stock 69 charger 440 R/T Auto Trans, 8 3/4 Suregrip.
