70 Bee Steering Column
CafnutS
6:02 AM
Alabama
I'm searching for repair kits for my 70 Bee Steering Column. The ones that I found are the following:
1. Lower Steering Column WHITE Bearing Kit
1970 Super Bee R/T GTX Charger RR Lower Steering Column WHITE Bearing Kit | eBay
2. Steering Shaft Coupler Rebuild Repair Kit
1964-78 Dodge A B C E F Body Steering Shaft Coupler Rebuild Repair Kit Mopar | eBay
Do I need anything else? I'm currently using my steering column and it's not in bad shape (No bends, corrosion or missing parts). I know the horn, turn signals, and ignition wire will have to be fix/inspected as well. I'm just trying to find a complete kit so I don't have to source from multiple place and save a S/H.
You might find them cheaper if you look around. I believe thats all you need except gasket to firewall. Remember turn single switch is one year only.
Thank you very much.
