I’ll start out by stating that this is part fact finding and part project.
The direction of this hinges on what information I can glean from others. In short, I need some help.
Our cars had some great features but one thing that the GM guys had that we didn’t was a tilt steering wheel. It seemed like they put those in all sorts of cars while we got nothing unless we drove an Imperial.
If another Mopar built before the 80s had a tilt wheel, I’d love to be corrected on that. (Oops, besides the Cordoba…more on that in a moment)
I had a 73 then later a 76 Camaro years ago. The 76 had tilt wheel and I loved it.
In 2008 or 2009 I put a tilt column in a Duster. The fitment was fine, I just had to shorten and weld the steering shaft to fit. That column came from a floor shift Chrysler Cordoba. I wish that I remember how I wired it up because that is my main obstacle here. I want to install a Cordoba steering column in my Charger. Years ago I pulled two from a self serve junkyard here in town.
Here is one of two that I have:
Unlike late model cars that only tilt from the firewall, old style tilt columns tilted above your thighs and are great for driving comfort as well as making it easier to enter and exit the car. This one would get cleaned and painted so don’t be bothered by the rough appearance.
When the key is turned, a steel rod moves forward.
This moves a section in this unit on the left with the yellow, red, blue and other wires to it. Four of the wires are 12 gauge, the two others are 14.
This has me thinking that they are for the ignition switch.
The other wiring is smaller gauge.
Chrysler used GMs Saginaw division for the tilt columns so they had a hybrid sort of harness as evident by the connectors not having matching color wires on each end. The smaller gauge harness is likely the turn signals, flasher, horn and cruise control!
Oh yeah, it has one of those courtesy lights for the ignition key cylinder.
I know that it is a long shot but has anyone else made this swap? I wish that I took better notes when I did this in the Duster 16+ years ago.
As a default, I guess I could look at a wire diagram for a Cordoba, huh ?
