Headlights out on 1 side only HiBeam 69 Charger
Macdon221
4:03 AM
Winnipeg, MB
Good Day all,
As per the title....69 Charger...Low beams work perfect on both sides (1 bulb on each side)....but when i switch to high beam...both lights come on as they should on the drivers side....but no lights at all on the passenger side (both bulbs off).
Any suggestions?
Thinking not the dimmer switch as it works on one side after the dimmer switch is "switched". So after that?
Thanks for your help
macdon221
First thing I would do is check to see if there’s power at the headlight plug. If not, work back from there…
Ground bad. There is a black wire for the right side and one for the left.
I agree with the ground on the side that is out. This happened to my Charger.
