Pic and dimensions needed, '70 rr floor pan.
torredcuda
9:24 AM
New Hampshire
Need pic of this bracket and location and pic, diameter and dimensions of gas pedal holes in the front floor pan.
I dont recall seeing or installing that particular bracket on any floor pan?
I took one off the original pan but it was rusty and had to make a new one so just want to make sure it looks like the factory one.
OK, I thought I found a blurry pic that showed double hooks. Mine must have had one side rusted off, I guess I`ll have to remake it. If you find better detailed pics that would be great. Thanks!
Not sure why my desk top won't load this one. Took a shot with my phone off my monitor.. Gas pedal left bolt hole is straight fwd from the last pan "roll"
My 70 RR has original floors - they were surprisingly in good shape and did not need replacement.
It is hard to get a good picture with the car on the lift. I can confirm what @dadsbee said that it is a double hoop. Note that mine is not used now because I have a Passon A-855 overdrive and the speedo cable is attached on the opposite side of the transmission.
Here is a picture of that same floor prior to restoration:
Thanks! I really thought mine was only one loop as it didn`t look like the other part was rusted off as it was a straight, clean edge. Unless there were two different versions - what plant was yours built at?
If you look closely at my picture of the pedal bolt holes, you can see the spot weld holding the speedo cable clip in place.
My car was built October 1969 in Los Angeles.
