67 Coronet Door glass question
JackpotJim
9:03 AM
Brainerd Minnesota
I have a friend in Bangkok Thailand with a 67 Coronet 2 door coupe that broke his driver’s door glass. Is the door glass on 67 Coronets the same for all 2 door models? Below is a photo of his car. Thanks!
Yes the glass is the same except on the post models. 66-67 side glass should be the same
There is also tinted glass and clear so he'll probably want to find matching glass.
66/67 Plymouth Satellite/Belvedere should also work.
I think I vaguely remember that '66 and '67 door glass are different. I have a full set of tinted glass in my 1967 R/T that I sourced from a 1966 Satellite. The top leading corner of my 1966 door glass has a little divot out of it to meet a corresponding seal at the top of the vent window frame. I don't think the 1967 glass has this detail. I could be wrong on this; as I say, it is a vague memory. I know that the rear quarter glass is different, because of how it is mounted to riser mechanism. Howerever, they are interchangeable. Perhaps someone on here with a 1967 B-body hardtop could confirm or refute my old memory.
You are correct, about them. 67 has a slant cut, 66 divot,
