S&JButler
What I need to know is is my dash frame and window surrounding metal trim the same color as the exterior or is it a different shade? Also is it shiny like the outside or is it more flat or satin? Thanks for any help.
It’s a 73.What I need to know is is my dash frame and window surrounding metal trim the same color as the exterior or is it a different shade? Also is it shiny like the outside or is it more flat or satin? Thanks for any help.
I think this is what I needed. So I wonder if I painted the dash frame the same color as the exterior and then put flat clear on it would it look correct?I’m not 100% sure what else you need but this is my 73 RR dash. You can see it’s a flatter shade of blue compared to my door jamb/exterior color. Let me know what else you are looking for and I will get it for you
after a little research I think this is what I have. My dash looks a lot like the one pictured in the post above and it’s definitely darker than the exterior..I often see Jamaica blue incorporated in b5 schemes
Is your dash frame darker than your other metal interior pieces? Ie the trim around the inside of the back glass and the pieces over the front windows.I’m not 100% sure what else you need but this is my 73 RR dash. You can see it’s a flatter shade of blue compared to my door jamb/exterior color. Let me know what else you are looking for and I will get it for you
