Drag slicks
PolaraFury
4:45 PM
MN
Hello,
I have a 67 Satellite that is 3200 ish #. I want to get a set of drag slicks for it.
Should I run a soft sidewall tire or something firmer?
I am also running Caltracs on stock springs
Cal tracks with stock springs wont be the best. The weaker the spring, the better. What shocks? What power level? Gear? Converter?
9 way adjustable Caltrac shocks on the back Caltrack 90/10 front. 600hp motor. 9” rear with 3:20 gears and 3K stall
Very liitle gear or converter. Drag radials will be the quickest. Should hook easily.
I agree the radials will be the quickest, but a bias will be more forgiving at a marginal track.
Is this a street car?
With the parts listed hooking a radial shouldn't be an issue.
We're lacking some info.. I had a 600hp 383 that didn't make any torque till 5500 rpm.. with the 3500 stall in it I could have run 225/70/14 Sears 4 ply belted radials...
Hello,
I run a 3500lb Charger. 28x10.5 on a 15. Caltracs system. 2500 stall Footbrake. Estimated 375hp. 3.91 gearing. Reverse manual valvebody. Hoosier for my door car only. I ran a DR2 dot for a while and liked it a lot but felt its durability was really poor (I’m very hard on it in the burnout.)
Only reminder is if you’re going to a slick, it needs a driveshaft loop.
