WTB OEM Front Wheel Cylinder Casting 2881630
robl72
5:34 PM
RI
Feedback: 1 / 0 / 0
OEM Front Wheel Cylinder Casting 2881630.. I believe it is the Drivers side. Looking for a good core for rebuild. Please PM if you have one.
Thank you!
No problem. I know i have some used but also some nos mixed in. Ill be at the warehouse monday morning. Ill post as soon as i get there.
Also Looking for
1. NOS Master Cylinder Lid covers 2823994. (Manual Double hump) if you have any.
2. Old Right Hand wheel studs for 69 Charger 11" Front drum/Hub.
I know both of these are long shots but figured I would ask.
Ill look in the stash
Can you give me measurements on the studs? I have them loose
1/2-20 Thread, approx 1" 7/8 in length. Should have an F stamped on the head and an "R" on the thread end. They are for a 69 B Body with front 11" Drum/Hub.
Ok
Studs will take awhile
I moved last year soooooo
Wheel cyl- only orig mopar i have left is a rear 2881613
All others new and used are wagner or similar
When i dig out the studs ill get back
Can you get them at napa?
