ncrobb
So while the car is off getting patch panels and some rust taken care I have time to ponder on an engine build. Right now it’s a completely stock 318, two barrel with a 3 speed manual trans. The little 318 runs good and has enough power to get around fine but that’s about it. Again, it’s a ‘73 Road Runner and she has the original 3.55 Sure Grip rear which I intend to keep. I have a freshly rebuilt A833 OD trans that I want to use. My overall goal for the car is to be a driver. Not necessarily an everyday driver but a couple days a week. I want to be able to run at highway speeds and light up the tires for a good exhibition pass. With the 3.09 1st gear and the .71 4th gear I think the OD trans will help cover that with the right engine. I have a 1979 360 that is std bore with a crank that has std main journals and turned .010” on the rod journals. The heads have a lot of wear in some of the valve guides. So I have been toying with a 408 stroker kit with around 9.5 or so CR and Edlebrock RPM heads with an RPM Air Gap intake and a 700-750 cfm vacuum secondary carb (maybe a little fuel efficiency here). If I go this route I’d call Comp Cams or Hughes and get a custom grind to make sure it all worked together. I think a decent working combo could easily put out 400-450hp on pump gas which should be enough to make the big car fun to drive and keep it rolling on the highway. Am I off base here? Would a stock bottom end 360 with higher CR pistons and the top end mentioned above be a better choice for a street car? I don’t anticipate any track or street “competition”. I got that out of my system many years ago. Nothing is set in stone, I guess I’m just thinking it through. Any thoughts on the 408 stroker in a driver?
