WileE
- 4:05 PM
- Sep 15, 2009
- State of insanity
Be careful, clothes may get wet101 right now in the high desert , monsoons are coming soon.
check for perspirationJust went out to check the thermometer on the back porch, in the shade. Only 20% humidity, but 119° F in the shade.
Edit: weather channel says its 124°
I don't think its anywhere near 102 where she is in that photo......just pointing that out.Be careful, clothes may get wet View attachment 1494737
120 sounds absolutely horrific. Stay hydrated while working.It’s currently 112 here at 8 pm. Could set a record tomorrow with 119 or 120. I’m not complaining, it makes up for the 27 below with windchill I worked in building houses in northern Illinois. I also remember back in 88, we had a big house going. The lady next door yelled over, it was 105. With the humidity, it was just as bad.
Stay hydrated while working.![]()
Yes sir, thanks. Luckily except for a some windows, doors or an addition or gazebo, I do mostly inside remods now. Wouldn’t build a house here, concrete work sucks.120 sounds absolutely horrific. Stay hydrated while working.![]()
High temperature and high humidity kills people.I like dry heat better than humidity and heat.
I had 90 at 8:30 in my shop this evening but I don't remember what the humidity was but I know it's probably 70% or more....and looks like y'all's weather there is about the same as here but looks like you have a better chance of rain. Our rain percentages are going down again since the high pressure that just left us a little bit ago is now coming back again from the west. I don't mind the heat too much if we had rain with it but it's just more of a pain in the butt trying to keep things alive outside. If we end up with a watering ban and let the grass die, weeds will take over. I rather mow grass any day than mow weeds.Forecast for today in Savannah, Ga was 93° F. In actuality, it hit 100° F late this afternoon; and the real feel temp. was reported to be 108° F.
At 8 p.m. (2 hours ago) it was 90°F and the real feel temp. was reported to be 99° F.
Our forecast for Tuesday is 102° F. It's a given that the humidity will be very high.
It's hot here, but other places are worse.
the past 3 weeks here have been brutal, and I doubt it's gotten over 88 degrees
Carlisle was a friggin sauna
I just found this:Everybody jokes about arizona being a "dry" heat, but it usually is. The other day was 124°f, according to the weather channel, but 4% humidity. I'll take that over 90°/90% anytime. 114°f, playing with the dogs today, around noon.
Air Temp. | 70°F 21°C | 75°F 24°C | 80°F 26°C | 85°F 29°C | 90°F 32°C | 95°F 35°C | 100°F 38°C | 105°F 41°C | 110°F 43°C |
Relative Humidity | ![]() (Degrees Fahrenheit/Degrees Celsius) | ||||||||
0% | 64°/18° | 69°/21° | 73°/23° | 78°/25° | 83°/28° | 87°/30° | 91°/33° | 95°/35° | 99°/37° |
10% | 65°/18° | 70°/21° | 75°/24° | 80°/26° | 85°/29° | 90°/32° | 95°/35° | 100°/38° | 105°/41° |
20% | 66°/18° | 72°/22° | 77°/25° | 82°/27° | 87°/30° | 93°/34° | 99°/37° | 105°/41° | 112°/44° |
30% | 67°/19° | 73°/23° | 78°/25° | 84°/28° | 90°/32° | 96°/35° | 104°/40° | 113°/45° | 123°/51° |
40% | 68°/20° | 74°/23° | 79°/26° | 86°/29° | 93°/34° | 101°/38° | 110°/43° | 122°/50° | 137°/58° |
50% | 69°/21° | 75°/24° | 81°/27° | 88°/31° | 96°/35° | 107°/42° | 120°/49° | 135°/57° | 150°/66° |
60% | 70°/21° | 76°/24° | 82°/27° | 90°/32° | 100°/38° | 114°/45° | 132°/56° | 149°/65° | |
70% | 70°/21° | 77°/25° | 85°/29° | 93°/34° | 106°/41° | 124°/51° | 144°/62° | ||
80% | 71°/22° | 78°/25° | 86°/29° | 97°/36° | 113°/45° | 136°/58° | 157°/69° | ||
90% | 71°/22° | 79°/26° | 88°/31° | 102°/39° | 122°/50° | 150°/66° | 170°/77° | ||
100% | 72°/22° | 80°/26° | 91°/33° | 108°/42° | 133°/56° | 166°/74° |
