- 6:47 AM
- Mar 10, 2010
- Hanover, Pennslyvania
Hotter ignition? You're stock with dual points?
175 should be doable for 93.....but....your domed pistons might be the achilles heel in this combination. I have experience with high comp engines (the highest was 11.5-1 with 180 psi) using flat tops but not domed. Domed pistons interfere with the flame front somewhat vs flat tops. One of the things you want to do with a tight quench is to force the fuel/air charge towards the spark plug (combustion chamber side of the head). In a nut shell, this helps create better swirl within the combustion chamber and a dome on top of a piston has a tendency to get in the way of that process. There's a ton of info on what takes place in a high performance engine combustion process if you want to spend the time doing research. It can make your head spin......well, it did mine anyways lol
something doesn't add up to me, if i understand this correctly. 175psi, 11:1 pistons with chambers that may be smaller than max wedge, small cam closing the intake valve around 65 degrees ABDC? unless i'm missing something, this doesn't make sense to me. cylinder pressure should be well over 200psi. i don't know how aussie octane ratings are derived but if they're like u.s. then 98 octane would be at least equal to our older 100 octane, maybe higher. i'm not getting 2+2=4 here,....?
have you checked the TDC mark on the dampner to make sure the outer ring hasn't slipped?
*****Regarding the 98 octane: *******
Our gasoline octane is rated based on the two testing standards that are added together, then divided by two.
RON is Research Octane Number. MON Is Motor Octane Number. This is the backstory behind the
R+M /2 that you see on the stickers affixed to the gas pumps. Some other countries only use one testing standard, the higher number of the two. This means that the Australian 98 octane may be equal to our 90 or 91 octane.
