Year ?
single ( or jumped if dual ballast ) blue wire, at ballast.
To keep power at cranking, splice blue wire from one side and brown wire from the other side wires together. That will eliminate the ballast for the HEI system.
The need to splice both is because on cranking moment the brown wire is what supplies the direct 12 volts to the coil bypassing the ballast for a while the blue wire is cut at ign switch, then on RUN, is the blue wire on the other side which feeds the coil going throught the ballast first.
So if you use just the blue wire coming from ing switch, when cranking you won't have power for ignition.
My question about the year is because when electronic regulator was equipped on cars ( between 69 and 70 ), the coil wire become on brown from the previous years when it was blue, like the one used to label the RUN circuit. So in Mech reg systems, ballast gets two blue wires one at each sides of ballast ( one from ign, the other one to the coil ), but one of them got one brown spliced in ( the one what links the cranking moment with the coil ). Then in elec reg systems, one side of the ballast gets TWO brown wires spliced into one side of ballast ( one for the coil and the other one what feeds when cranking )and the other side jus the blue ( from ing in RUN )
