robinsonwr
Yes, I just realized that Hoosier makes a 275 55 14 Quik Time DOt tire which has minimum rim requirement of 6". The question is has anyone used this tire before? I know most everyone is going with 15" or better wheel tire combos. The reason this appeals to me is I can use the original wheels and hubcaps for an even more stock appearance. Oh yes, 66 Satelllite with 440/512, stealth heads, 600 lift hyd roller, 11:1 compression, TCI street fighter 727, 3000 stall, and 3:23 8.75 w/sure grip. The tire is about an inch less section width and an inch shorter than a 275 60 15. The specs for the tire are below:
275/55 14
Wheel Diameter 14 in.
Sidewall Style Solid white letters
Tire Construction Bias-ply
Directional No
Tire Diameter 26.10 in.
Section Width 10.10 in.
Tread Width 8.50 in.
Minimum Recommended Wheel Width 6.00 in.
Maximum Recommended Wheel Width 8.00 in.
How it compares to Tire Size 255/60-15
Wheel Diameter 15 in.
Tire Construction Radial
Directional No
Tire Diameter 27.00 in.
Section Width 10.24 in.
Tread Width 8.20 in.
Minimum Recommended Wheel Width 7.00 in.
Maximum Recommended Wheel Width 9.00 in.
275/55 14
Directional No
Directional No
