Crumley
Superfreak and Homstead thank you for the reply's.
The tight door gap was bugging me. To get the needed door gap, a small cut off wheel was used in rotary end cutter. The 1/4 panel was cut along the curve. The yellow line is where the cut will end.
The 1/4 panel curve was pushed back using screw drivers to check the gap.
A single cut wasn't deep enough, so the slot was enlarged about the thickness of 2 cut off wheels. The screw drivers re-inserted between the door and 1/4 panel to get the needed gap. The panel is currently just randomly tacked. The enlarged radius will be welded out before the body work is completed.
