Jeremiah
I would be looking for a problem with how the system is designed in this case. I ran a 500" stroker in my '66 with iron heads and lot of compression with a 185 thermostat. I used a Champion 3-row radiator with a 14 or 16" single electric fan and it never went over 215 in traffic out here in the desert.
Do you happen to have a infrared thermometer that will show what the actual-ish temp is in the inlet hose, outlet hose, and on the thermostat housing? That may help us enderstand what is happened when the car warms up.
Also, how much ignition timing do you have at idle speed? Are you 100% sure that the timing mark on the damper is actually TDC? If you had the timing way advanced this could cause your overheating issue if you are wondering where I am going...
