Update:
Passenger turn signal housing: back on the market
Trunk Lid : back on the market
Driver Fender : Rust free from a different car
Hood : Rust free from a different car
Slashing prices!!!!!! Everything must go, need room for more parts and cars!
1) Driver rear 1/4 panel, perfect wheel arch - you tell me where you want it cut - $225
2) Passenger rear 1/4 panel, perfect wheel arch - you tell me where you want it cut - $225
3) Rust and Dent Free Trunk Lid - $150
4) Rust free driver fender - very light cosmetic damage - $150
5) Stainless windshield molding - no damage, needs to be polished - $65
6) Stainless back glass molding - no damage, needs to be polished - $65
7) Rear back light (glass) + gasket - no scratches, chips or delamination - $175 ( as far as I know these are not reproduced )
8) Complete small block front accessory package including alternator, brackets, pulleys, fan and bolts, unmolested - $115
9) Original small block radiator, I will get the tank number - very nice, can pressure test if you are interested - SOLD
10) Small block, non A/C front wiring harness (with light wiring, etc), complete and uncut, very nice and not UV damaged - $75
11) Non-A/C Dash cluster, chrome plating deteriorated, needles sun-faded, radio opening un-cut, circuit board pins very nice - $200
12) Rust free Driver and Passenger fore/aft fender splash shields with hardware, clips and flaps - $50
13) Rust free doors, complete, your choice - $75, I will make you a deal on more than one!
14) Column shift steering column w/ steering wheel, 66 only part, some surface rust that will clean up, 100% intact with nice feeling original turn signal switch - SOLD
15) Manual steering box, nice condition, not road tested, consider it a core - $125 I can send this to firm feel for you and save you shipping $ if you are not in the NW.
16) Small block 727 TF (I think, I'll re-check trans model) kick-down/throttle linkage, with original springs and clips - $60
17) Factory horns with mounting bolts - Failed bench test, cores only - $20
18) Nice original heater box complete with controls/cables - $150
19) Front turn signal switch housings - excellent sockets - $40 for the pair
20) Nice uncut dash frame, will clean up nice (correct mounting screws included) - $125
21) Wiper Arms -bright - Nice condition - $50
22) Wiper motor - decent core - plastic switch plate - $50
22) Wiper motor linkage w/ pivots - will need reconditioning - $50
23) V-8 K frame - nice - $75
24) .890 torsion bars - nice w/ no rust or abrasions - $100
25) Any front suspension parts - make me a reasonable offer!
26) Sedan headliner bows - nice, not rusty - $75
27) Metal glove box door with screws and hinges - $40
28) Complete 71k mile 273/auto carb to oil pan fan to tail shaft. Very original tin, etc. $250, *local p/up only unless you have lost your mind and want to pay shipping on this one*
29) Complete dash wiring harness, non-A/C, uncut - $150
30) Ash tray w/ slider and h/w - $35
31) Factory painted, non-chromed rear view mirror w/ hardware - $25
