- 2:21 AM
- May 14, 2011
- On the Ridge, TN
I wonder when the last time the valve lash was checked was?
I suspect this is exactly the reason Plymouth changed it; nobody could figure out what it meant. 426 Hemi is self-explanitory.That is an interesting carb linkage system. I would suggest getting the stock carbs restored and going back to them but might depend on how well it runs with the Edelbrocks.
Edit - glossed over the rear springs too quickly - no, not stock.
I always thought HP2 stood for Hemi Power, Second (2) generation. Maybe someone knows the definitive answer.
My upper hose also is over the top of the fuel line but depends on what upper hose is used. The original upper hose seems to be out of production.
Nope, checked, they are Monroe. Really light blue vs the dark blue they come now.Are your front shocks by any chance Gabriels?
I can find them both ways, so hopefully someone has an unrestored, never tinkered, original engine car to confirm. I've found a bunch with about a 50/50 split of how it's run. This one is same as mine, straight thermo housing as well.
Unfortunately.. no.Did you get the stock air cleaner base with it?
Front pad on the block isn't even stamped.Love the car! Actually all your cars! Just wondering if it has a vin on the block being a 68. Also,I would have a look at the master cylinder from interior side to make sure there is no leak inside vehicle. Just a thought. Thanks for the great info and pics.
