1967 GTX license plate mounting question
GTX Rod
5:47 PM
pennsylvania
1967 GTX license plate mounting question: does the plate bolt directly to the bumper or is there a bracket that should be mounted to the bumper? There are 2 round holes that seem like I could bolt the plate through and secure it but I want the check if there’s something missing.
G
Round holes or square holes? There are plastic inserts that snap into the holes. Then you use screws into the plastic to secure the tag. There is also a small body bumper that goes into a third hole to keep the tag from rattling against the bumper.
directly to the bumper.
should be 2 square holes that take a plastic insert for the screws to go into
Thanks for the replies!
It has round holes and I have the square plastic inserts that should work. I also think I can use a through bolt and nut setup as well.
