1967 gtx turn signal indicator placement
wsf1966
4:35 AM
ohio
Mine were gone and holes filled. Anyone got pictures and measurements for where they go? Thanks
Are you sure your car originally had the fender mounted turn signals? They were an option. If your car has active turn signals in the instrument cluster then it wasn't originally equipped with fender mounted signals. If I'm just telling you something you already know and they really were filled in, I should think you could find indications of filler or weld material on the underneath. the fender.
They are on the tag and looks like a piece of metal on the bottom of fender. Assumed that's how holes were filled
Wanted to bump this. I picked up a set and could someone measure from the back of their fender along the peak to the rear base of the indicator for me? Had some numbers from the front and I don't trust measuring around the curve. Thanks guys
the signal rides on an angle on the fender body line... from body line of fender to driver’s door measure 48 1/4........ on my gtx letters it lines up with the “E”........
