1968 Charger Sway Bar Dilemma
Charger Too
10:52 AM
Illinois
Is it possible my 318 Charger did not come with a sway bar and links? I don’t see any tabs on the lower control arms. Should I install one, even if it did not come with one originally? If so, are the aftermarket kits okay to use? Thanks
Not a dilemma at all.
Parts could have been swapped, or I didn't get one. If you want one, put one on.
Some aftermarket's hang down too low.
I like the factory parts.
What are the pros and cons with them? Is it possible my car did not come with one? Can I attach a tab to my control arm? Weld or bolted on?
Yes they can be added. I think pretty much all aftermarket kits come with bolt on tabs if your lca doesn't have them. I had no bars at all on my 69 for almost 15 years. She'd lean in corners but it wasn't unenjoyable to drive. Kinda like driving a dirt car. I put front and rear bars on it a couple years ago and been autocrossing it. I think the front bar will make the car feel flatter for you in a corner but I think it'll plow without also having a matched rear bar. For street driving thats no problem. The only downside to a front bar is my oil filter won't come out the bottom of my car. Not sure why that's the case or if it's normal but I can get it out the top so no problem.
Personally...I've never seen a 68 charger without a sway bar from the factory...318 or not.
$49 at Jegs part number
515-23366​
Look at Hellwig's sway bar that uses the bottom shock stud.
It's NICE and simple with no welding.
Good quality bar from a very respectable MFG.
Find yourself factory lower arms with tabs and a factory sway bar and be done with it. It all fits and it looks right. It's a little more work but it will be. Worth it in the end. If you can't find the parts let me know I have everything of my 69 r/t that I'm not using
I just installed front and rear sway bars from Summit. Once the front bar is in place the tabs can be welded. Maybe drive it a bit to see where the tabs want to seat. If helps I can send a better photo of the tabs on Monday.
Can they be welded on with the lower control arm installed on the car?
Looks good, which front sway bar from summit is that?
It is the 1.125
ACO-K1-541-0U
Sway Bar, Black, Steel, Front, 1 1/8 in. Diameter, Dodge, Plymouth, Kit
(Mfr. #: 541)​
ADKq_NZJKzaSJ74jX5Edf7s0V9OCoU0fRqGyjA3nmToaknYlp-O5870vCO7qsM4W_zpFjLwHwRQWD_rGkMuf_2pivZeHYsvVs4FEzNNCpslFl-bXi7wr8UZY2HHOtiM=s0-d-e1-ft
Ready to Ship
Ground​
$230.56​
1​
$230.56​
I have a set of mount tabs that will work $100 with hardware.
Also have a rear sway bar.
If end up swapping out the lower control arms I would suggest putting in heavier torsion bars at that time.
You can also just weld on tabs to your existing lower control arms.
