Except for the A833.Generally speaking more splines equals stronger.
Yes, generally.Generally speaking more splines equals stronger.
Yes and when you go with more splines they generally aren't cut as deep which reduces the shaft diameter as well.Yes, generally.
In this case, the 18 spline has a larger diameter shaft and stronger gears. It’s not the spline count that makes it stronger or less strong, in this case
That very well may be, but in this case, it does not apply. The 18 spline is stronger.Yes and when you go with more splines they generally aren't cut as deep which reduces the shaft diameter as well.
Hi I hear you but I can't leave it auto, all that power not in my full control. Nothing beats changing manual gears when you want to, hitting those revs at the sweet spot and then changing.IMHO, I would leave it automatic. 30 yr 4 speed owner here. Think of what you can do with those funds elsewhere on the car. Opinions are like...
I converted my coronet RT. The engine is numbers matching but the trans was not.
I really don’t give a crap about the value of the car. That said, I doubt it hurt the value any, and may have additional value to the next owner. I saved every part, so the next owner could convert it back if they wanted to.
To me, the car was extremely boring as an auto. With the 4 speed, it’s a blast.
