1968 Plymouth GTX
There is a chrome piece that the rear interior quarter panels fit into.
Does anyone know what they call it or have a part number for it?
Trying to find stuff in my '68 Service Manual and '68 Complete Parts List is like looking for a needle in a haystack.
The circled part?
My block has been bored .030" oversized and inspected for any cracks or defects. Everything looks good according to the shop so I placed an order
for the following which will arrive by Friday:
Sealed Power Forged Pistons L2355F30 (.030” oversized, 2.061” high)
Sealed Power Rings SLP-E424K30 (for above pistons)
King Main Bearings MB5116SI STDX (stock size)
Sealed Power Rod Bearings 82130CP (stock size)
He is supplying the cam bearings and brass freeze plugs.
I will take the crank, connecting rods, flexplate and harmonic balancer to him when I deliver the above so he can check to see if balancing is necessary.
Also order the headliner, interior rear window trim, new dome light lens, carpet and door sill plates and windlace.
Plan is to get the remaining interior trim painted first and then begin the installation nightmare.
Prepping upper rear interior quarter trim.
I use guide coat while wet sanding as it helps me see all imperfections:
Painted:
Uh, You need to pull the front glass to install the headliner!
I installed the headliner on my signature car with the windshield in place. My plan is to do the same as removing that windshield is something I cannot do by myself.
The clips are all accessible so I think it can be done.
PLEASE post some pictures! I understand where the clips are at but wow, do you have teenie little fingers!
I'm still searching for a headliner and carpet. The stuff I got wasn't the right color so I sent it back.
Have two places sending me samples of their blue materials.
Okay, I ordered this set of rear window interior trim pieces but cannot figure how this bottom one is supposed to go in.
I read an entire thread on these things but all that did was confuse me as to whether I have the right trim for my car?
Mine was built in October of 1967, so a very early build date. Would this make a difference as to the kind of trim used?
