1969 440 fuel pump
paul1969cars
1:29 AM
new york
hi
Can you tell me what fuel pump will be close to what came on the car originally?
I'm trying to set up a stock / factory look. I have the correct tube from fuel pump to vapor separator
I purchased a Carter m4434. But it seems that the outlet side of the fuel pump is not at the correct angle so that the small steel fuel line from fuel pump to vapor separator is not aligned. My 383 car has a fuel pump with the outlet at a wider spread than the carter I purchased. But I dont know that manufacture
If I could trouble you for the correct fuel pump then that would
be great.
looking for this setup
I believe only 440/426 had the vapor separator not 383
No vapor separator. A fuel filter goes in between the carb line and fuel pump line.
Matt
