1969 Charger 440 RT # location.
19charger70
12:14 AM
Cleveland
Im looking at what is supposed to be a numbers matching 69 Charger 440 RT which I found in the south......Where are the numbers at where I should be looking for? Besides the numbers on motor pad which is on passanger side right?
Transmission, another pad, rad support, driver's side trunk gutter.
Make sure the VIN starts with XS also.
Engine number should be on the passenger side of the block, stamped into the bottom of the block towards the front just above where the sump is....I think.
VIN# should be on the fender tag (inner fender next to battery), trunk gutter (driver side under weatherstripping), Radiator support (top rail), motor (pad just above oil pan), transmission pad, and build sheet (if you're lucky enough to have one).
Numbers matching means different things to different people. Some folks think numbers matching means the original drivetrain is still in the car. Others think that EVERY part has the correct date code- carb, distributor, alternator, starter, plug wires, rims, radiator-EVERY part on the car being correct for the build date of the car.
Obviously the latter requires much more research and is a very difficult goal to attain.
