A pillar trim in place.
Drivers side showing the correct #10 washer head screws. The ones in the repro kit had the wrong heads, but you can buy correct ones at NAPA.
Don't miss the screw up under the dash.
Hope you put these windshield trim retainers in before you installed the windshield! (you could get them in now, but wouldn't be fun)
The windshield to headliner trim was previously painted the same flattish black as the dash. It does not get painted gloss TX9 like the other interior trim pieces. #8 x 5/8" oval head screws x 6.
Windshield to headliner trim in place, over top of the A pillar trim pieces.
Headliner to roof rail trim uses 6 of these clips and one screw.
Clips slide it place like so. This is the the drivers side, picture taken from the front looking rearward.
3 on the front door section and three on the rear seat area. I used a bit of butyl to hold them in place so they didn't slide off while installing.
Screw goes about 4" from the front end, into the roof rails screw slot. Rubber hammer used to knock the trim clips tight onto the headliner mounting edge.
View attachment 750955 View attachment 750956 View attachment 750957 View attachment 750958 View attachment 750959 View attachment 750960 View attachment 750961 View attachment 750962 View attachment 750963 View attachment 750964
