- 8:12 PM
- Jan 29, 2018
- Midland Ontario, Canada
New reproduction gas pedal
Floor drilled to match carpet and pedal installed. I drilled about 5/16" forward of the correct measured position I had on the floor pan. Not bad considering the patched up mess the pedal was attached to when I installed this carpet in '88.
Similar deal with the dimmer switch that was also mounted in a patched up mess when the carpet was installed in '88. It should be on that formed boss about an inch to the right and up 3/4", but it'll live here!
Shifter boot installed with 4 # 10 stainless screws. Then the carpet put back and deco ring installed with 4 x # 10 oval head screws.
New shifter ball, that is correct for assembly line. I've always had a hurst T handle and have a date correct new one that will probably find it's way back into the car in time.
Getting there!
New Ebrake, clutch and brake pedal covers.
Pedal covers all in place.
5 lb fire extinguisher back into it's home.
The list is getting shorter....
Getting there!
