JimKueneman
Ah the memories of 4 months ago!
Memories or nightmares? Lol, I hate cutting and buffing. Plenty of runs to deal with thats for sure, cannot wait until I am DONE with the body. The whole car for that matter....so I can drive it![]()
You've been restoring items in the background and not sharing that information haven't you![]()
Are you using SPI black epoxy primer for the under body detail part?
Ah yes, time for the details and more details![]()
And finally, I modified my ballast resistor with a straight piece of wire. I am going to use a Pertronix II ignition and coil which doesn't use the resistor but I like to maintain the factory look. Cleaned the old housing up and pulled it apart. Pretty simple, the resistor is just crimped on. I cut a length of wire, stripped the ends and soldered them into the terminal ends. To keep the terminals in place, I used the left over bit of Acraglas to hold the wire in the ceramic housing.
View attachment 387681 View attachment 387682 View attachment 387683 View attachment 387684
So is that like aluminum foil around the fuze?![]()
