1969 Plymouth Spring Special Package A14/A15
Big D A12
11:09 AM
Wausau, WI
I am doing some research and am looking for the document describing the A14/A15 package. It is mentioned in PIB 12 in the last paragraph under Road Runner. See attached.
Thank you!
D
Here's a listing I found for both A14/A15 codes. Hopefully the info listed is correct.
Unfortunately, I don't have a brochure or anything to reference - this is an amalgamation of some old posts on here and from around the web:
"A14 1969 Spring Special: Consisted of a Vinyl roof, Magnum road wheels, 3-speed wiper motor, Power steering, Belt moldings, Black hood paint, Longitudinal stripe, Sure grip rear end, and Different F70 tires.
A15 1969 Spring Special: - same as A14 except Without the Vinyl roof."
Hopefully someone else has some documentation that can confirm or refute these package contents.
*Edit to strike out a couple erroneous inclusions.
Here's the comparison of A14 and A15 packages for Satellites and Road Runners from window stickers.
Please remember the RM27 would come standard with the belt molding so that's why it's not listed in the package.
Just what the doctor ordered @69Coronetrt :)
Nosin' around and found a nice example that clearly has 2-speed wiper motor/no J25, so that was erroneous. The window stickers show power steering likely not a part of the package either even though this particular car happens to have it.
As described above, the A14 package is different for each model. Photo of Production Option Code Book listing for A14 and A15.
Although the OP was inquiring about the Roadrunner, here is a breakdown of the "A14 Satellite Spring Special Package A" just in case anyone can use this info.
What was included in certain packages can vary by by make, model and body style so sometimes we have to drill down to get the details as to the topic.
While the glove box lock was included in, say, the Dart A01 package, it was not included in the Satellite A01 package.
I would venture to say that MOST of the online or published sources do not get into the necessary detail required to explain this so our, as usual, best source for accurate information is typically factory documents like window stickers or order sheets.
