1970 Mopar B Body looking for info on wheel back spacing and tire choice
ruready67
New Member
3:15 AM
Santa Clara
Did QA1 upper control arms upgraded torsion bars and rear hemi rear leaf springs from Mancini racing looking to run front 15x8 Mag wheel with a 4 1/2 back spacing with a 235/60/15 tire. In the back looking to run a 15x10 mag wheel with a 275/60/15 Jegs telling me this set up works. Any real time actual experience welcomed does this sound correct to u guys thanks for your time and input
There's a few different 70 b body wheel wells, what are you working on.
Mopar Joe uses 15x8's with a 255-60/15. I don't know what he uses on the front. 7" standard offset but no clue on tire size.
you could go to a P295-50-15, 12"-ish of girth, 28"-ish diameter
on the back fit good, look good too
on a 10" wide wheel, 5.25-5.50" (IIRC) backspacing
(don't take it for granted do the measurement yourself)
you could do check with a 18"x 24" builders/carpenters square,
or a good straight edge & a tape measure
measure from the face of the brakes where the wheel butts up-to
back to the springs & the other direction to the wheel lips
if you go too tall or too wide, the tires
it will rub at the top of the inner wheel well
on a hump inside on the outside of the inner well
or on the lip/trim edge
good luck
I have a 275/60 on a 8" wheel, with 4" back space, and they rub equally inside and out when the car is loaded pretty heavy and maybe driven a little aggressively.
However I have a '66 B body housing, which is a little narrower than a 68 housing.
