1973-1974 Roadrunner & GTX and Satellite Pic Thread
just an update, I done a bit more body work-n-painted it a few days ago :)
It has been so long since I've looked at this thread. I need to catch up! Great look Runners!
I didn't tub it at all. All i did was move the springs in with the offset spring hangers. put an "A" body rear end in it (relocated the perches) and that was it. The tires are about 11 1/4" wide, 30" tall, the rime is 10".
the car is also lowered a couple of inches.
If you don't mind, What back spacing? 5 or 5.5? Drums in back or disc? I was going to step up to a 10 inch rim (have 8inch with 4.5 now) with ladder bar coil over conversion and run 315/60R15s very similar tire and width to yours. About to order a S60 Strange rear end and was debating getting the A body rear, and don't want to Mini tub if I dont have too.
That is a beautiful car and love the color. I have seen only one in this color in person and its a stunning color. Post up some pics if you got them.
Sorry I didn't see this post. The color is Dark Moonstone Metallic (brown).
Gulfport MS. nice car Katrina didnt get that one. What size tires are you running? My Satellite was the same color with red top.
I got it from a guy in Hattiesburg after Katrina. Not sure of tire size I think its 225/70-14 cars at sons house putting motor back in. I had one just like yours back in the day. Drove it every day for years.
1974 Roadrunner..... It was my first car i bought when i was 14 in 1990. Originally was a 318 3-speed manual. Now it's a lot more than that.
440ci R3 Siamese race small block 11.1 compression (pump gas)
4.185 bore 4" stroke
Eagle 4340 steel crank
Eagle 6.123 H-beam rods
Diamond pistons
Indy 360-1 fully CNC'd W2 aluminum heads with 2.10 x 1.65 valves
K-Motion roller valve springs
Titanium retainers
T&D 1.5 roller rockers
Comp solid roller cam & lifters .276/.284 - .658/.661
Indy ModMan intake port matched with dual 750cfm Eddies
MSD Pro-Billet dizzy
MSD 6AL-2 ignition
MSD HVC-2 coil (Installed after these pics were taken)
Quicktime steal bellhousing
Mopar Perf. high torque starter
Griffin aluminum rad with dual electric fans
Aeromotive Steath 340 Phantom sumped electric fuel pump (installed after these pics were taken)
Optima yellow top battery
3.5" custom drive shaft
Drive shaft loop
1 7/8" TTI ceramic coated headers
3" TTI ceramic coated X-Pipe exhaust
Flowmater Super 10 series mufflers
TKO 600 trans
McLeod twin disc clutch hydraulic actuated
Dana 60 w/4.10 and Eaton Tru-Trac LSD
Wilwood 4 wheel discs
Hydrabooster
March billet serpentine acc drive
71 side marker lights
71 exhaust reliefs in rear valance
71 Hemi choke handle
71 chin spoilers
71 Gull Wing
71 Roadrunner head grill emblem
Subframe connectors
Lower core support
Front and rear bumpers narrowed and tucked
Borgeson quick ratio steering box
Firm Feel 1-1/4" Front 7/8" rear sway bars
Firm Feel 1.12" road racing torsion bars
Firm Feel solid aluminum k-frame mounts
Firm Feel solid aluminum torsion bar crossmember mounts
Calvert split mono leaf drag racing leaf springs
CalTracs Linked traction bars
Custom made Legendary seat covers
Entire inside covered in DynaMat Extreme
Modernized original AM/FM radio
Leather wrapped TuffWheel
Engine made
660hp @ 7000rpm
575tq @ 5100rpm (At the crank)
View attachment 272600View attachment 272601
Almost put those wheels on mine but decided on going with chromed 15" rallyes...... Looks good
1973 Satellite Sebring Plus
I bought this 73 Sebring Plus a couple of days ago. Very happy with it so far. Numbers matching, un-restored, survivor. Factory 400, 4 barrel, 4 speed car with 59k miles.
[video=youtube;AddipzYgDP4]https://www.youtube.com/watch?v=AddipzYgDP4[/video]
well an update, i took the tunnel ram off, flat blacked the hood and have been driving this thing while i build my '65 Belvedere...
I do what to say that i love to see all the cars on this site... I think all these road runners and satellites are awesome!
