Typically, 318 got the 904 trans and the 8-1/4 rear.
The fender tag will tell you the trans code.
The brodacst sheet will tell you the rear axle size and the final gear ratio-without opening 'er up.
Hope this helps.
Ma mopar is known to do odd things and change them up.
Mid year 1973 all B body wagons got the 9-1/4 rear as the 8-3/4 was slowly being phased out.
My wagon has the 9-1/4 rear behind the 318/3 speed manual trans.
