WTB 1973 Road Runner quarter panels
FREDDIEBEAR
New Member
9:52 AM
OHIO
I am new to the website and looking for quarter panels. No luck with my buddies out West or south, but someone mentioned a guy in Canada that may have the molds to make them. Any suggestions would be greatly appreciated.
There's a guy on FBBO that makes 66/67 quarter panels.
I've not heard of him, or anyone else, making 73/74 panels.
For a while, AMD made panels from the 12 o'clock position of the wheel arch back.
There's a rumor, and I own both and can verify it's real close...
...that you can use a the wheel arch section of a 72-80 truck fender!
I've also heard this, luckily, I don't need them, but I will have to put a little thought into comparing the two. That would definitely be a good thing to know for future projects. Has anyone ever seen them cut out and lined up as a replacement? Share your knowledge if you have.....lol
"Cheap" truck fenders are available from LMC Truck-
https://www.lmctruck.com/body-compo...iy4qeR6Ud47vPlhlh7fs9HMS_00cy7HsGM0-vXr8nobzy
...and it looks like a truck wheel arch is also available-
1580-147 L Key Parts Wheel Arch Repair Panel Driver Left Side Upper Hand | eBay
Might be worth the $$ or $$$ just to see for sure.
...assuming the stamping is correct.
The last time I compared them, even the line behind the arch matched the line on the B body!
However, I want to say the left side on the truck matched the right side on the car.
That's if my memory is working correctly.
Do the truck fender arch panels have the secondary styleline also?
