Most of the mufflers for 3 in are are actually 2.5 internally.
3 in pipes are louder with the same muffler.
Problem I have with the 3 is it is a tight fit and occasionally rattles against the frame or shocks as it goes over the axle. Using flowmaster tailpipes on 72 B body.
Yep. I have 3" all the way back on mine as well; it came that way when I bought it.
It's obvious some exhaust shop made it up; it has the single chamber Flowmasters on it as well.
Is it loud? Depends on how old you are, I suppose.
Yes, it's rather obnoxious when you're tromping on it and even when you're just coasting between buildings going through town.
My wife says she can hear it coming for about a block away.
No crossover on it. That would help some with the noise level.
I have been under there more than once, tweaking on it here and there. Exhaust systems do move a little while going down the road and yes, the bigger pipes find ways of vibrating off something, especially the over the axle area, where things get really congested under there.
Something not yet mentioned is that larger pipes don't sound like the original stuff, either. I know that's nothing tangible, but Mopars always had a distinctive sound to them when new; you could spot one from a ways off because of it.
Some of that distinctive sound is the exhaust system, of course, including pipe sizing and muffler types. Even the exhaust tips make a difference on some Mopars.
Just saying.
