SPeaking of 62-63 Mopar
we had a Stage II wedge stick shift car, later hung on the aluminum kit and switched back and forth with a torqueflyte, upgraded to stage III, found out it ran better with a fire slot in the dome- etc
Isky developed his first and ONLY .904 lifter optimised cam and we were- well I thought we were the first test car- found out later that several of us were
Later Racer Brown came out with one- really consistent I'd still use one to dial in a chassis
I just moved an early 4 speed with the companion flange not slip yoke if anyone needs it- this one is stock
I do not recommend the cross ram on the street- use the 6 pack just think of them as a 4 bbl with two secondaries- tunes just the same and well worth it
If you are looking for looks either works- but I agree- long rams on a street roadster look the bestI did one with 4-71s on it, tried a tunnel ram with a 6-71-- both worked well until a backfire... but they looked awesomne
