Outsider
Glad you're seeing an improvement. Years ago I used to have a Sun distributor machine, but sold it when it had seemed to have sat for a couple decades. When I had time after retirement again, I did about 4 distributors in last couple years with the car sitting in the driveway with a tach meter in the engine compartment, a timing light and paper on a clip board to record the timing at the various rpms, and then changed the springs until I got what I thought I needed. Then I took it for a test drive going up a hill to put an additional load on it, judged the power by the seat of my pants, and listened for ping.
Did you map the rate the timing comes in at 500 rpm intervals and run it up to 4k or so, to see when it's all in? I ask because most of my big blocks like 16 deg initial or more, but on pump gas don't like much more than 34deg total mech. And after you figure it out without the vac adv, and then hook it up, often it is only better as the vac adv only adds when the load is low and the vac is high.
